Pololu Blog (Page 89)
Low-cost hexapod
Posted by Kevin on 24 June 2011
A Mini Maestro 24-channel USB servo controller controls three servos in each of this insectoid robot’s six legs. For more information, see this thread on the Trossen Robotics forums.
How an idea becomes a product
Posted by Jan on 22 June 2011
The Wixel Shield for Arduino that we released today represents a personal milestone because of what I did not do on it: the shield is the first electronic product made by Pololu that I did not design. That’s not to say I did not have some input on it or that other engineers here did not have substantial contributions to other products, but the Wixel Shield is a first because the basic product concept, the circuit design, and physical implementation (i.e. the PCB layout) were all done by someone else. We also just finished a big facility expansion that was taking up a lot of my attention this year, so I have some more time now to think about our design process and what it takes to go from a new idea to a finished product. Continued…
Instructable: Introducing the Wixel USB Wireless Module
Posted by Ben on 6 May 2011
This Instructable by customer Michael Oz introduces the reader to the Wixel through a series of basic projects.
RC servo speed control
Posted by Jan on 6 May 2011
It is often desirable to control the speed and acceleration of hobby RC servos. Understanding your options can be confusing since there are various speeds involved, many similar terms are used, and the terms are not used consistently by different companies or end users. You might also have an idea of what you want your servo to do without knowing what to call it or how to describe it or how to implement it. To get a good understanding of what is going on, it is helpful to picture the position of your servo in relation to the commands you are sending it. A simple first attempt might look like this: Continued…
Advanced hobby servo control using only a timer and interrupts
Posted by Jan on 5 May 2011
In this last article about generating pulses for hobby servo control, I will present what I think is the best solution to controlling many servos or controlling some servos while still leaving enough processing time to do other tasks. It’s not that easy to make this approach work well, so my recommendation in most cases is just to get one of our servo controllers, which use this technique. Continued…
Learning PID values using simulated annealing
Posted by Ben on 29 April 2011
This is a video of a robot based on the Pololu 5" robot chassis that automatically improves its PID constants over time.
Featured link: http://www.youtube.com/watch?v=TdquX0lPlYY
Advanced hobby servo control pulse generation using hardware PWM
Posted by Jan on 28 April 2011
So far, I have discussed a very simple circuit and a very simple microcontroller approach to generate the control pulses needed to control hobby servos. For some applications, those methods are sufficient, but we often want either to control many servos or to do something in addition to controlling servos, and that is when the limitations of the simple approaches and the demands of the servo interface become more apparent. In this post, I will move on to some more sophisticated techniques to generate servo control pulses. Continued…
Motion simulator chairs
Posted by Ben on 21 April 2011
Jrk 12v12s are used as part of two-degree-of-freedom motion-simulator chairs (sim chairs) in this project posted to the XSimulator forums. Here is a video of some initial testing using the Jrk Configuration Utilty:
For more details see the forum post.
New Products
24V, 50mA Isolated Step-Up Voltage Regulator U5Z9F24
TPS2116 Power Multiplexer Carrier with USB Type-C Connector (non-USB priority)
ACS37030LMYATR-040B3 Current Sensor Large Carrier -40A to +40A, 3.3V
Pololu Basic 2-Channel SPDT Relay Carrier for "Sugar Cube" Relays with JST SH-Style Top-Entry Connector
ACS37200LLXTR-100B5 Current Sensor Large Carrier -100A to +100A, 5V
ACS37200LLXTR-150B5 Current Sensor Compact Carrier -150A to +150A, 5V
MPQ6612A Single Brushed DC Motor Driver Carrier (Soldered Connectors)
