Pololu Blog (Page 79)
New product: Machined Aluminum Bracket for 37D mm Metal Gearmotors
Posted by Kevin on 2 August 2013
Tags: new products
We have released a new machined aluminum bracket that lets you securely mount our 37D mm metal gearmotors to your project. The bracket has six holes on its face that line up with the 37D gearbox’s mounting holes, and it has three tapped holes on the bottom. Nine M3 screws are included for securing the bracket to the motor and mounting surface.
New products: QTR-3A and QTR-3RC Reflectance Sensor Arrays
Posted by Kevin on 1 August 2013
Tags: new products
Our new QTR-3A and QTR-3RC reflectance sensor arrays pack three IR emitter and receiver (phototransistor) pairs onto a board measuring just 1.25″ × 0.3″ (32 mm × 8 mm). With the sensors mounted on a 0.375″ pitch, these sensor arrays are great for sensing 3/4″ black electrical tape when used as minimal detectors on line-following robots!
Two versions of these sensor modules are available: the QTR-3A provides three analog voltage outputs, while the QTR-3RC provides three digital pulse signals that can be read with digital I/O lines.
New product: Sparkfun Starter Kit for RedBoard
Posted by Kevin on 30 July 2013
The SparkFun Starter Kit for RedBoard is an easy way to get started building entertaining and educational circuits with SparkFun’s RedBoard, an Arduino clone that is compatible with the Uno R3. The kit includes a RedBoard along with various types of sensors and indicators. A downloadable guide features example projects to introduce you to the world of embedded electronics.
Lunokhod
Posted by Paul on 8 July 2013
Lunokhod, which means “Moon Walker” in Russian, was built for a space museum in Prague and is a miniature version of the first remote-controlled moon rover. It uses 8 of our 298:1 micro metal gearmotors and an Arduino Nano and can be remotely controlled by museum visitors. The rover was built by Beatty Robotics; you are can learn more about it on their blog.
Simple 18-servo hexapod
This instructable shows how to make a simple 18-servo hexapod robot that uses either just an Arduino or an Arduino and a Maestro to control its servos.
Featured link: http://www.instructables.com/id/Simple-18dof-Hexapod-Arduino-nano-optionally-wit/
New products: Step-up Voltage Regulators U1V11F3, U1V11F5, and U1V11A
Posted by Claire on 5 July 2013
Tags: new products
We have released three new step-up regulators that can boost input voltages as low as 0.5 V and have typical efficiencies between 70 and 90%. Unlike most boost regulators, these offer a true shutdown option that turns off power to the load. They also automatically switch to a linear down-regulation mode when the input voltage exceeds the output, making them great for powering electronics projects from 1 – 3 NiMH, NiCd, or alkaline cells or from a single lithium-ion cell.
These regulators are available with a 3.3 V or 5 V fixed output voltage or an adjustable output voltage (2 V – 5.25 V).
Underwater Vehicle for MATE ROV Competition
Posted by Ryan on 27 June 2013
The AMNO & CO ROV team uses our Simple Motor Controllers in their remotely operated underwater vehicle. The team placed 13th at the 12th Annual MATE International ROV Competition (and 2nd in regionals)!
Featured link: https://www.facebook.com/AMNOandCoROV
Ball casters
Posted by Emily on 25 June 2013
Tags: pricing
We’ve lowered the prices on all of our ball casters! Prices have dropped by $1 to $2 across the whole Pololu ball caster line and start as low as $1.99.
Flight Testing of a Surrogate UAV at the National Test Pilot School
Posted by Paul on 17 June 2013
This “optionally piloted aircraft” is a Cessna 150 that customer Ryan Olson fitted with an autopilot and remote control system using the Pololu jrk 12v12. It is used for UAV training and development at the National Test Pilot School in Mojave, CA. Ryan’s AUVSI 2012 abstract is available online, and you can see some pictures of the internals below.
Labeled diagram of the inside of Ryan Olson’s optionally piloted Cessna 150.
Jrk 12v12 enclosure used in Ryan Olson’s optionally piloted Cessna 150.
New Products
ACS37100LMATR-025B3 TMR Current Sensor Large Carrier -25A to +25A, 3.3V
Glideforce GF01-121003-2-66 Micro Linear Actuator with Feedback Potentiometer: 12V, 4.3kgf, 17.6mm/s, 30mm Stroke
TB67S579FTG Stepper Motor Driver Compact Carrier
Magnetic Encoder Pair Kit with Side-Entry Connector for Mini Plastic Gearmotor, 12 CPR, 2.7-18V
APM81815 Step-Down Voltage Regulator Carrier, 5.35V Out
APM81815 Step-Down Voltage Regulator Carrier, 12V Out
TB67S579FTG Stepper Motor Driver Carrier - Full Breakout
Glideforce GF01-120510-2-66 Micro Linear Actuator with Feedback Potentiometer: 12V, 2.2kgf, 28mm/s, 100mm Stroke
