3.11. Schematics and dimensions
Schematics
The schematic diagram for the Romi 32U4 Control Board is available as a PDF: Romi 32U4 Control Board schematic diagram (646k pdf).
Dimensions
A basic dimension diagram for the Romi 32U4 Control Board is available as a PDF: Romi 32U4 Control Board dimension diagram (604k pdf).
Dimensions that are not included in the above diagram can be measured from the following DXF, which shows the main board outline along with the sizes and locations of all of the holes on the board: Romi 32U4 Control Board drill guide (346k dxf).
The following picture shows the approximate dimensions of the Romi chassis which is intended to be used with the Romi 32U4 Control Board:
Basic dimension diagram of the Romi Chassis.
Romi Robot Kit for FIRST - Red
