Support » Pololu Romi 32U4 Control Board User’s Guide » 3. Romi 32U4 Control Board »
3.10. AVR timers
- Timer0 is used by the Arduino environment for timing-related functions like
millis(). - Timer1 is used by the Romi 32U4 Control Board Arduino library for driving motors.
- Timer3 is not used by the Romi 32U4 Arduino library and can be freely used for your own purposes.
- Timer4 is used by the Romi 32U4 Arduino library for controlling the buzzer. The buzzer pin (digital pin 6, or PD7; Timer4 output OC4D) can be freed for other uses by cutting the surface-mount jumper labeled “6 = Buzzer”.
