Pololu Blog (Page 88)
Android-controlled Mini Sumo Robot
Posted by Ryan on 6 January 2012
Pololu forum user Mert Öztoprak posted this parts list and the short video above of a Android-controlled mini sumo robot called “Karafatma”.
November 2011 update: new building, new machines
Posted by Jan on 30 November 2011
Five months ago, I wrote that we “just finished a big facility expansion that was taking up a lot of my attention this year, so I have some more time now …” Well, that turned out to be wrong. It’s also been over a year since I started this blog, and so far, I am way behind my target of an article per week. It doesn’t help when I don’t post for four months, but some exciting stuff has happened in that time. Continued…
Simple 3pi Projects for the Arduino IDE
Posted by Ben on 8 August 2011
These projects by Daniel J. Sullivan are intended to introduce novice users to all the components on the 3pi robot and how they can be used while programming with the Arduino IDE. Each project builds on the one before it, and comments within the programs are used to provide background information when new items are introduced.
Continuous-rotation servos and multi-turn servos
Posted by Jan on 26 July 2011
As I discussed in the introduction to servos, one of the consequences of hobby servos’ intended use is that rotation range is limited to about 180 degrees. In this post, I will talk about two exceptions to this general rule: continuous-rotation servos and multi-turn servos. Each of these products loses some features in return for increased rotational range, so none of them are the ideal actuators many would like them to be. There are some specialty servos developed for robot applications that get around the limitations, but those servos are not as standardized and do not really fit into the hobby servo category, so I am not going into any more detail on those beyond mentioning that they exist. Continued…
"Mr. Twitchy" project featuring Wixels
Posted by Ben on 8 July 2011
Mr. Twitchy is a project that uses two Wixels to wirelessly control an electrical stimulation device. The project was featured in Sparkfun New Product post.
"Blackbeard's Chest" animatronic display
Posted by Ryan on 1 July 2011
Blackbeard’s Chest by SkullTroniX uses two jrk motor controllers with feedback to control linear actuators as part of a spooky animatronic display.
New Products
2.5-9V Adjustable Step-Up/Step-Down Voltage Regulator S9V11E2A
ACS37200LLXTR-200B3 Current Sensor Large Carrier -200A to +200A, 3.3V
Magnetic Encoder Pair Kit with Top-Entry Connector for Mini Plastic Gearmotor, 12 CPR, 2.7-18V
ACS37200LLXTR-100B5 Current Sensor Large Carrier -100A to +100A, 5V
120:1 Mini Plastic Gearmotor HP, Offset 3mm D-Shaft Output, with 12 CPR Encoder, Back Connector
Glideforce GF01-121003-2-66 Micro Linear Actuator with Feedback Potentiometer: 12V, 4.3kgf, 17.6mm/s, 30mm Stroke
TB67S579FTG Stepper Motor Driver Carrier - Full Breakout
