Save 15% on “active” status Pololu-brand products using code MEMORIALDAY26
5. Programming the Balboa 32U4
The Balboa 32U4 control board is designed to be programmed over USB from the Arduino IDE. It can be programmed from Windows, Linux, and Mac OS X. The ATmega32U4 on the control board comes preloaded with the same USB bootloader as the A-Star 32U4 family of general-purpose programmable ATmega32U4 boards. The following sections will help you get started programming your Balboa 32U4.
Bumper Cage Kit for Balboa
Balboa 32U4 Control Board
