Support » Pololu Motoron Motor Controller User’s Guide » 4. Pinout »
4.7. Motoron M3T453 pinout
Pinout of the Motoron M3T453 Triple I²C Motor Controller with JST SH-Style Connectors. |
Pinout of the Motoron M3T453 Triple I²C Motor Controller with 0.1″-Pitch Through-Holes. |
The diagrams above identify the control and power pins on the Motoron M3T453. Section 3.2.1 explains how to connect motor power, motors, and a microcontroller.
The Motoron’s logic is powered from the VDD pin, and it is controlled via I²C through the SCL and SDA pins (see Section 6). Additional GND pins provide a common ground reference between the Motoron and device controlling it.
The VM pin provides access to the reverse-protected motor supply voltage.
The ERR pin, which is only available on the version with 0.1"-pitch through-holes, drives high when the red LED is on, which usually indicates an error as described in Section 5. The ERR pin is protected by a 220Ω series resistor. When the red LED is not on, the ERR pin is pulled down weakly.
The JMP1 pin can be shorted to the adjacent GND pin to allow the Motoron’s I²C address to be changed, as detailed in Section 3.5. Also, shorting JMP1 to GND at startup causes the Motoron to ignore the address configured in EEPROM and use 15 as its I²C address instead.
