6.12. Schematics and dimensions
The schematic diagram for the Zumo 2040 robot is available as a PDF:
- Zumo 2040 schematic diagram (369k pdf)
Dimensions
Basic dimension diagrams are available as PDFs for the assembled Zumo 2040 robot and its circuit boards:
- Zumo 2040 Robot dimension diagram (1MB pdf)
- Zumo 2040 Main Board dimension diagram (2MB pdf)
- Zumo 2040 Front Sensor Array dimension diagram (664k pdf)
Dimensions on the boards that are not included in the above diagrams can be measured from these DXF drawings:
- Zumo 2040 Main Board drill guide (89k dxf)
- Zumo 2040 Front Sensor Array drill guide (49k dxf)
3D Models of the Zumo 2040 are also available in STEP format:
- Zumo 2040 Robot 3D model (42MB step)
- Note: This model uses simplified models of the control electronics to reduce the file size.
- Zumo 2040 Main Board 3D model (23MB step)
- Zumo 2040 Front Sensor Array 3D model (6MB step)
The following pictures show the approximate dimensions of the Zumo chassis used by the Zumo 2040 robot:
