1. Tamiya Gearbox Gear Ratio Comparison
Tamiya makes a variety of gearboxes that are perfect for building small robots. The following table shows the different gear ratios supported by each model to help you select the Tamiya gearbox that best fits your needs.
  • The first row links to all of the different Tamiya gearbox kits.
  • The second row links to the motor specs for each gearbox (view the model number in the link).
  • The remaining rows indicate which gear ratios each gearbox supports.
70168
89918
double
70167
89917
single
70097
89915
twin-motor
70093
89914
3-speed
70103
universal
70110
89916
4-speed
72001
planetary
72002
high-speed
72003
high-power
72004
worm-gear
72005
6-speed
motor
(#18100)
FA-130 (58k pdf)
(#18100)
FA-130 (58k pdf)
(#18100)
FA-130 (58k pdf)
(#18100)
FA-130 (58k pdf)
(#18100)
FA-130 (58k pdf)
(#18100)
FA-130 (58k pdf)
(#2295)
RC-260 (60k pdf)
(#2295)
RE-260 (59k pdf)
(#2295)
RE-260 (59k pdf)
(#2295)
RE-260 (59k pdf)
(#2295)
RE-260 (59k pdf)
motor
worm gear
X X
X
worm gear
4:1
X
4:1
5:1
X
5:1
12:1
X
X 12:1
12.7:1 X
X
12.7:1
16:1
X
16:1
17:1
X
17:1
18:1
X
18:1
20:1
X
20:1
25:1
X
25:1
30:1
X 30:1
38:1 X X
38:1
42:1
X
42:1
58:1
X X
58:1
65:1
X
65:1
77:1
X 77:1
80:1
X
80:1
100:1
X
100:1
101:1
X
101:1
115:1 X X
115:1
126:1
X
126:1
197:1
X 197:1
204:1
X X
204:1
216:1
X
216:1
269:1
X
269:1
336:1
X
336:1
344:1 X X
344:1
400:1
X
400:1
441:1
X
441:1
506:1
X 506:1
719:1
X
719:1
1301:1
X 1301:1
1543:1
X
1543:1
5402:1
X
5402:1
70168
89918
double
70167
89917
single
70097
89915
twin-motor
70093
89914
3-speed
70103
universal
70110
89916
4-speed
72001
planetary
72002
high-speed
72003
high-power
72004
worm-gear
72005
6-speed
Tamiya 89914 3-Speed Crank-Axle Gearbox Kit - Clear
Tamiya 89915 Twin-Motor Gearbox Kit - Clear
Tamiya 89916 4-Speed Crank-Axle Gearbox Kit - Clear
Tamiya 89917 Single Gearbox Kit - Clear
Tamiya 89918 Double Gearbox Kit - Clear
Tamiya 70097 Twin-Motor Gearbox Kit
Tamiya 70168 Double Gearbox Kit
Tamiya 70093 3-Speed Crank-Axle Gearbox Kit
Tamiya 70167 Single Gearbox (4-Speed) Kit
Tamiya 70110 4-Speed Crank-Axle Gearbox Kit
Tamiya 70103 Universal Gearbox Kit
Tamiya 72001 Planetary Gearbox Kit
Tamiya 72002 High-Speed Gearbox Kit
Tamiya 72003 High-Power Gearbox Kit
Tamiya 72004 Worm Gearbox Kit
Tamiya 72005 6-Speed Gearbox Kit
