3.d. Programming your Arduino
Our Arduino library for the dual TB9051FTG motor driver shield makes it easy to get started writing your Arduino sketches. A link to download the library, installation instructions, and the library command reference can be found on the library’s github page or you can download the library from within the Arduino IDE by going to Sketch > Include Library > Manage Libraries… and then searching for DualTB9051FTGMotorShield, selecting the library, and then selecting Install.
Once installed, we recommend you try out the example sketch by selecting File > Examples > DualTB9051FTGMotorShield > Demo from the Arduino IDE, or by copying the following code into a new sketch:
#include "DualTB9051FTGMotorShield.h"
DualTB9051FTGMotorShield md;
void stopIfFault()
  if (md.getM1Fault())
    Serial.println("M1 fault");
    while (1);
  if (md.getM2Fault())
    Serial.println("M2 fault");
    while (1);
void setup()
  Serial.begin(115200);
  Serial.println("Dual TB9051FTG Motor Shield");
  md.init();
  // Uncomment to flip a motor's direction:
  //md.flipM1(true);
  //md.flipM2(true);
void loop()
  md.enableDrivers();
  delay(1); // wait for drivers to be enabled so fault pins are no longer low
  for (int i = 0; i <= 400; i++)
    md.setM1Speed(i);
    stopIfFault();
    if (abs(i)%200 == 100)
      Serial.print("M1 current: ");
      Serial.println(md.getM1CurrentMilliamps());
    delay(2);
  for (int i = 400; i >= -400; i--)
    md.setM1Speed(i);
    stopIfFault();
    delay(2);
  for (int i = -400; i <= 0; i++)
    md.setM1Speed(i);
    stopIfFault();
    delay(2);
    md.setM2Speed(i);
    stopIfFault();
      Serial.print("M2 current: ");
      Serial.println(md.getM2CurrentMilliamps());
    delay(2);
    md.setM2Speed(i);
    stopIfFault();
    delay(2);
    md.setM2Speed(i);
    stopIfFault();
    delay(2);
  md.disableDrivers();
  delay(500);
This example ramps motor 1 speed from zero to max speed forward, to max speed reverse, and back to zero again over a period of about 3 s, while checking for motor faults and periodically printing the motor current to the serial monitor. It then performs the same process on motor 2 before repeating all over again.
Note: Even if you do not have any motors yet, you can still try out this sketch and use the motor indicator LEDs for feedback that the shield is working properly.
Dual TB9051FTG Motor Driver Shield for Arduino
