8.6. Example serial code for Linux and macOS in C
The example C code below works on Linux and macOS. It demonstrates how to use the USB virtual serial port or the TTL serial port to get the error status from the controller, read a variable, and set the target speed.
For this example to work, the Simple Motor Controller G2’s input mode must be Serial/USB, the serial mode must be Binary, and the CRC must be disabled. These are the default settings that the controller is shipped with. If you are using TTL serial, you should set the controller to use a fixed baud rate of 9600, or change the baud rate in the code below to match whatever fixed baud rate you choose.
// Uses POSIX functions to send and receive data from a // Simple Motor Controller G2. // NOTE: The Simple Motor Controller's input mode must be set to Serial/USB. // NOTE: You must change the 'const char * device' line below. #include <fcntl.h> #include <stdio.h> #include <unistd.h> #include <stdint.h> #include <termios.h> // Opens the specified serial port, sets it up for binary communication, // configures its read timeouts, and sets its baud rate. // Returns a non-negative file descriptor on success, or -1 on failure. int open_serial_port(const char * device, uint32_t baud_rate) { int fd = open(device, O_RDWR | O_NOCTTY); if (fd == -1) { perror(device); return -1; } // Flush away any bytes previously read or written. int result = tcflush(fd, TCIOFLUSH); if (result) { perror("tcflush failed"); // just a warning, not a fatal error } // Get the current configuration of the serial port. struct termios options; result = tcgetattr(fd, &options); if (result) { perror("tcgetattr failed"); close(fd); return -1; } // Turn off any options that might interfere with our ability to send and // receive raw binary bytes. options.c_iflag &= ~(INLCR | IGNCR | ICRNL | IXON | IXOFF); options.c_oflag &= ~(ONLCR | OCRNL); options.c_lflag &= ~(ECHO | ECHONL | ICANON | ISIG | IEXTEN); // Set up timeouts: Calls to read() will return as soon as there is // at least one byte available or when 100 ms has passed. options.c_cc[VTIME] = 1; options.c_cc[VMIN] = 0; // This code only supports certain standard baud rates. Supporting // non-standard baud rates should be possible but takes more work. switch (baud_rate) { case 4800: cfsetospeed(&options, B4800); break; case 9600: cfsetospeed(&options, B9600); break; case 19200: cfsetospeed(&options, B19200); break; case 38400: cfsetospeed(&options, B38400); break; case 115200: cfsetospeed(&options, B115200); break; default: fprintf(stderr, "warning: baud rate %u is not supported, using 9600.\n", baud_rate); cfsetospeed(&options, B9600); break; } cfsetispeed(&options, cfgetospeed(&options)); result = tcsetattr(fd, TCSANOW, &options); if (result) { perror("tcsetattr failed"); close(fd); return -1; } return fd; } // Writes bytes to the serial port, returning 0 on success and -1 on failure. int write_port(int fd, const uint8_t * buffer, size_t size) { ssize_t result = write(fd, buffer, size); if (result != (ssize_t)size) { perror("failed to write to port"); return -1; } return 0; } // Reads bytes from the serial port. // Returns after all the desired bytes have been read, or if there is a // timeout or other error. // Returns the number of bytes successfully read into the buffer, or -1 if // there was an error reading. ssize_t read_port(int fd, uint8_t * buffer, size_t size) { size_t received = 0; while (received < size) { ssize_t r = read(fd, buffer + received, size - received); if (r < 0) { perror("failed to read from port"); return -1; } if (r == 0) { // Timeout break; } received += r; } return received; } // Reads a variable from the SMC. // Returns 0 on success or -1 on failure. int smc_get_variable(int fd, uint8_t variable_id, uint16_t * value) { uint8_t command[] = { 0xA1, variable_id }; int result = write_port(fd, command, sizeof(command)); if (result) { return -1; } uint8_t response[2]; ssize_t received = read_port(fd, response, sizeof(response)); if (received < 0) { return -1; } if (received != 2) { fprintf(stderr, "read timeout: expected 2 bytes, got %zu\n", received); return -1; } *value = response[0] + 256 * response[1]; return 0; } // Gets the target speed (-3200 to 3200). // Returns 0 on success, -1 on failure. int smc_get_target_speed(int fd, int16_t * value) { return smc_get_variable(fd, 20, (uint16_t *)value); } // Gets a number where each bit represents a different error, and the // bit is 1 if the error is currently active. // See the user's guide for definitions of the different error bits. // Returns 0 on success, -1 on failure. int smc_get_error_status(int fd, uint16_t * value) { return smc_get_variable(fd, 0, value); } // Sends the Exit Safe Start command, which is required to drive the motor. // Returns 0 on success, -1 on failure. int smc_exit_safe_start(int fd) { const uint8_t command = 0x83; return write_port(fd, &command, 1); } // Sets the SMC's target speed (-3200 to 3200). // Returns 0 on success, -1 on failure. int smc_set_target_speed(int fd, int speed) { uint8_t command[3]; if (speed < 0) { command[0] = 0x86; // Motor Reverse speed = -speed; } else { command[0] = 0x85; // Motor Forward } command[1] = speed & 0x1F; command[2] = speed >> 5 & 0x7F; return write_port(fd, command, sizeof(command)); } int main() { // Choose the serial port name. // Linux USB example: "/dev/ttyACM0" (see also: /dev/serial/by-id) // macOS USB example: "/dev/cu.usbmodem001234562" // Cygwin example: "/dev/ttyS7" const char * device = "/dev/ttyACM0"; // Choose the baud rate (bits per second). This does not matter if you are // connecting to the SMC over USB. If you are connecting via the TX and RX // lines, this should match the baud rate in the SMC G2's serial settings. uint32_t baud_rate = 9600; int fd = open_serial_port(device, baud_rate); if (fd < 0) { return 1; } int result = smc_exit_safe_start(fd); if (result) { return 1; } uint16_t error_status; result = smc_get_error_status(fd, &error_status); if (result) { return 1; } printf("Error status: 0x%04x\n", error_status); int16_t target_speed; result = smc_get_target_speed(fd, &target_speed); if (result) { return 1; } printf("Target speed is %d.\n", target_speed); int16_t new_speed = (target_speed <= 0) ? 3200 : -3200; printf("Setting target speed to %d.\n", new_speed); result = smc_set_target_speed(fd, new_speed); if (result) { return 1; } close(fd); return 0; }
