Resources » Pololu Dual MC33926 Motor Driver Shield User's Guide » 3. Getting Started with an Arduino »3.a. What You Will NeedThe following tools and components are required for getting started using this motor driver as an Arduino shield:
* Note for Due users: The voltage on the current sense pins will exceed the Due’s 3.3 V limit when the current draw exceeds ~6 A. The CS circuit has a 1 kΩ resistor in series with the output, which offers some protection to the analog input, and the driver has over-current protection that kicks in between 5 A and 8 A, so the risk to the Due is low, but if you really want to be safe, you can use a 3.3 V zener diode to clamp the current sense output voltage to a maximum of ~3.3 V. Alternatively, you can disconnect the shield’s current sense pins from the Due (and optionally reconnect them through a voltage divider); see Section 6.a for more information. |
Wish Lists
BIG Order Form
Shopping Cart
(702) 262-6648 |
