Resources » Pololu Maestro Servo Controller User's Guide » 3. Getting Started »3.c. Using the Maestro without USBIt is possible to use the Maestro as a serial servo controller without installing any USB drivers or using a PC. Without using USB, you will not be able to change the Maestro’s settings, but you can use the default settings which are suitable for many applications. The default settings that the Maestro ships with are described below. Default Settings
Wish Lists
BIG Order Form
Shopping Cart
(702) 262-6648 |
