2. Laser-engraved wood handgun case
Laser engraving is a great way to personalize anything, including a handgun case, as shown here.
We raster-engraved this walnut handgun case using the red “Colt” logo shown below. During raster engraving, the laser burns away a very thin layer of material to create a recessed area in the specified shape. Since the laser is burning the material, the wood might get darker or even charred depending on the type of wood and any stains, glues, or other chemicals that have been applied to the wood. In this case, the laser roughened the surface a bit but did not leave it looking charred.
If you are concerned about charring, you can always start by having us engrave a small sample, first. You might also be able to remove some of the charring by sanding. Note that many plastics including acrylic/Plexiglas do not char from the laser
Image file used to laser-engrave a wooden handgun case.
When laser engraving a prefabricated piece such as this handgun case, we align the engraving by eye; although the logo might look well-centered, it could be off by a few millimeters (or even more) in any direction, depending on the details. Alignment is not an issue if we are also laser cutting the edges of the part.
Please also see our example of laser-cut wood, which also illustrates some laser charring. To get started with laser cutting your own parts, see our custom laser cutting service page.
New Products
5V, 100mA Step-Down Voltage Regulator D45V1E1F5
RobustMotion RM-EGB Series 24VDC Compact Finger Gripper, 20D, Simple PNP Interface
ACS37041KLHBLT-030B3 Current Sensor Micro Carrier -30A to +30A, 3.3V
Pololu I²C Isolator, ISO1640
JST SH-Style Cable, 2-Pin, Female-Female, 25cm
12V, 100mA Step-Down Voltage Regulator D45V1E1F12
CT432-HSWF30DR TMR Current Sensor Compact Carrier 0A to 30A, 5V
JST SH-Style Cable, 4-Pin, Female-Female, 40cm
ACS72981LLRATR-100U3 Current Sensor Compact Carrier 0A to 100A, 3.3V
1.4-7V, 3.8A Fine-Adjust Step-Down Voltage Regulator w/ Adjustable Low-Voltage Cutoff D30V33MALCMA
