1. Laser-cut ABS in replica light sabers
Internal assembly of saber handle showing stacked laser-cut parts.
These light sabers made by Michael Murphy illustrate how two-dimensional laser-cut parts can be stacked to create three-dimensional pieces. If you look closely at the black cylindrical parts in the light saber handle, you can see that some of them are assembled from two-dimensional circular parts (similar to the ones shown in the layout on this page) that we laser cut from sheets of ABS plastic.
ABS is a relatively strong plastic that resists cracking, so it is appropriate for mechanical parts that need to withstand some stress or impact. We stock black ABS in several thicknesses: 1/4", 3/16", 1/8", and 1/16". If you are mainly concerned with how a part looks, or if your part does not need to be particularly sturdy, you might consider using acrylic instead: it is protected with paper masking, it comes in a variety of colors, and it is cheaper to laser cut.
To get started with laser cutting your own parts, see our custom laser cutting service page.
Layout for laser cutting stackable parts.
New Products
A5984 Stepper Motor Driver Carrier, Adjustable Current, Blue Edition (Soldered Header Pins)
CT432-HSWF30DR TMR Current Sensor Compact Carrier 0A to 30A, 5V
ACS72981LLRATR-050B5 Current Sensor Large Carrier -50A to +50A, 5V
1.4-7V, 3.4A Fine-Adjust Step-Down Voltage Regulator w/ Adjustable Low-Voltage Cutoff D30V30MALCMA
TB67S581FNG Stepper Motor Driver Carrier (Soldered Header Pins)
CT433-HSWF65DR TMR Current Sensor Large Carrier 0A to 65A, 3.3V
ACS37042KLHBLT-030B3 Current Sensor Compact Carrier -30A to +30A, 3.3V
ACS72981ELRATR-200B3 Current Sensor Compact Carrier -200A to +200A, 3.3V
CT433-HSWF50MR TMR Current Sensor Large Carrier -50A to +50A, 3.3V
