1. Introduction
This guide is for an older version of the QTRSensors Arduino library (3.1.0). The current version of the library can be found on GitHub, and its documentation is here.
QTR sensor size comparison. Top row: QTRX-HD-07, QTR-HD-07; middle row: QTR-3, QTR-1, QTR-L-1; bottom row: QTR-8.
The Pololu QTR reflectance sensors carry infrared LED and phototransistor pairs that can provide analog measurements of IR reflectance, which makes them great for close-proximity edge detection and line-following applications. The modules come as compact, single-sensor units (QTR-1A and QTR-1RC; QTR-L-1A and QTR-L-1RC), 3-sensor arrays (QTR-3A and QTR-3RC), or as 8-sensor arrays (QTR-8A and QTR-8RC) that can be optionally split into a 2-sensor array and a 6-sensor array.
The modules are available in two different output formats: the QTR-xA outputs an analog voltage between 0 and Vcc that can be measured by an analog-to-digital converter (ADC), and the QTR-xRC outputs require a digital I/O line capable of driving the output line high and then measuring the time for the output voltage to decay (which provides an analog measurement of reflectance).
QTR-L-1A reflectance sensor schematic diagram.
QTR-1A reflectance sensor schematic diagram.
QTR-1RC and QTR-L-1RC reflectance sensor schematic diagram.
Please see the product pages for more information on how these sensors work.
This document will explain how to install Arduino libraries for the Pololu QTR reflectance sensors, and it will provide sample sketches as well as links to library documentation. The libraries will give you everything you need to interface with a QTR-8x reflectance sensor array or multiple QTR-1x reflectance sensors, including advanced features like automatic calibration and, in the case of line detection, calculation of the line’s position.
New Products
CT433-HSWF30MR TMR Current Sensor Compact Carrier -30A to +30A, 3.3V
Pololu Isolated USB-to-I²C Adapter
A5984 Stepper Motor Driver Carrier, Fixed 1.5A@5V / 1A@3.3V, Blue Edition
Pololu Reverse Voltage Protector, 4-60V, 12A
ACS37030LLZATR-020B3 Current Sensor Compact Carrier -20A to +20A, 3.3V
1.4-7V, 3.4A Fine-Adjust Step-Down Voltage Regulator w/ Adjustable Low-Voltage Cutoff D30V30MALCMA
JST SH-Style Connector Board for Micro Metal Gearmotors, 2-Pin, Back-Entry (10-Pack)
ACS37042KLHBLT-010B3 Current Sensor Compact Carrier -10A to +10A, 3.3V
ACS71240KEXBLT-030B3 Current Sensor Carrier -30A to +30A, 3.3V
