3.10. Pin assignments
The table below lists the most important pin assignments for the ATmega32U4 on the A-Star 32U4 Robot Controller with Raspberry Pi Bridge. This table is helpful if you want to add your own electronics to the robot controller, write your own low-level code for interfacing with the hardware, or just want to understand better how the A-Star works. Each row represents a physical pin on the ATmega32U4.
The “Arduino pin names” column lists the names provided by the Arduino environment for the pin. These names can generally be used as arguments to any function that takes a pin number. However, there are some exceptions. For example, passing the number 4 to analogRead actually reads pin A4, not pin 4. Also, due to hardware limitations, some functions only work on a limited set of pins.
The “A-Star 32U4 Robot Controller functions” column documents what the pin is used for on the A-Star 32U4 Robot Controller. Many pins can serve multiple purposes concurrently by switching modes. For example, PB0 can read the state of button C when it is an input, and it can control the red LED when it is an output.
The “Notes/alternate functions” column documents other features of the pin, although some of those features might be impractical to use.
ATmega32U4
pin name
Arduino
pin names
functions
PB3 14, MISO User pushbutton A SPI Master Input/Slave Output (MISO)
Pin-change interrupt (PCINT3)
ISP programming line (PDO)
PB0 17, SS Red LED (RX)
User pushbutton C
SPI slave select (SS)
Pin-change interrupt (PCINT0)
PC7 13 Yellow LED Timer4 PWM output A (OC4A)
Timer3 input capture pin (ICP3)
Divided system clock output (CLKO)
PD5 - Green LED (TX)
User pushbutton B
UART external clock (XCK1)
UART flow control (CTS)
PD6 12, A11, 29 Motor 1 direction Analog input (ADC9)
Timer4 PWM output D (OC4D)
Timer1 counter source (T1)
PB5 9, A9, 27 Motor 1 PWM Analog input (ADC12)
Timer1 PWM output A (OC1A)
Timer4 PWM output B (OC4B)
Pin-change interrupt (PCINT5)
PE2 - Motor 2 direction Hardware bootloader select (HWB)
PB6 10, A10, 28 Motor 2 PWM Analog input (ADC13)
Timer1 PWM output B (OC1B)
Pin-change interrupt (PCINT6)
PD0 3, SCL I²C clock for Raspberry Pi communication Timer0 PWM output B (OC0B)
External interrupt source (INT0)
PD1 2, SDA I²C data for Raspberry Pi communication External interrupt source (INT1)
PD7 6, A7, 25 Free I/O
Jumper to buzzer PWM
Analog input (ADC10)
Timer0 counter source (T0)
PF6 A1, 19 Free I/O
Jumper to battery level input (VIN/3)
Analog input (ADC6)
JTAG test data out (TDO)
PD2 0 Free I/O UART receive pin (RXD1)
External interrupt source (INT2)
PD3 1 Free I/O UART transmit pin (TXD1)
External interrupt source (INT3)
PD4 4, A6, 24 Free I/O Analog input (ADC8)
Timer1 input capture pin (ICP1)
PC6 5 Free I/O Timer3 PWM output A (OC3A)
PE6 7 Free I/O Analog comparator negative input (AIN0)
External interrupt source (INT6)
PB4 8, A8, 26 Free I/O Analog input (ADC11)
Pin-change interrupt (PCINT4)
PB7 11 Free I/O Timer0 PWM output A (OC0A)
Timer1 PWM output C (OC1C)
UART flow control (RTS)
Pin-change interrupt (PCINT7)
PB1 15, SCK Free I/O SPI Clock (SCK)
Pin-change interrupt (PCINT1)
ISP programming line (SCK)
PB2 16, MOSI Free I/O SPI Master Output/Slave Input (MOSI)
Pin-change interrupt (PCINT2)
ISP programming line (PDI)
PF7 A0, 18 Free I/O Analog input (ADC7)
JTAG test data in (TDI)
PF5 A2, 20 Free I/O Analog input (ADC5)
JTAG test mode select (TMS)
PF4 A3, 21 Free I/O Analog input (ADC4)
JTAG test clock (TCK)
PF1 A4, 22 Free I/O Analog input (ADC1)
PF0 A5, 23 Free I/O Analog input (ADC0)
RESET - Reset pushbutton internally pulled high, active low
AREF - - Analog reference
