6. Compiling and running the program
Instructions for compilation are defined in the Makefile. Type make and all of the C files will be combined into a shared object (or DLL) called ssctester.so. Since there is no main function, this is not a program you can run by yourself, just a library of functions that will be used by ssc-tester.tcl. That file is a script, which means that it is interpreted on the fly and does not need to be compiled. To run it, type
wish ssc-tester.tcl
and a window with 16 sliders should appear. Connect the servo controller and a servo, then try moving the sliders to see if it works!
New Products
Graphical OLED Display: 128x64, 1.3", White Pixels, SPI, Black PCB
ACS72981KLRATR-150B3 Current Sensor Compact Carrier -150A to +150A, 3.3V
ACS71240KEXBLT-010B3 Current Sensor Carrier -10A to +10A, 3.3V
Ribbon Cable with Pre-Crimped Terminals 10-Color M-F 60" (150 cm)
ACS724LLCTR-05AU Current Sensor Carrier 0A to 5A
ACS71240KEXBLT-050U5 Current Sensor Carrier 0A to 50A, 5V
4.2-15V, 3A Fine-Adjust Step-Down Voltage Regulator D30V30MAS
LPS22DF Pressure/Altitude Sensor Carrier with Voltage Regulator
3.3V Step-Up/Step-Down Voltage Regulator S8V9F3
