5. Adding a GUI with Tcl/Tk
Tcl/Tk is the most convenient way to create GUIs that will work on both Windows and Linux. Even if you only use one system, you will benefit from the fact that Tcl/Tk is quite easy to learn and used by a lot of people. The particular mix of Tcl/Tk and C that we recommend here was the best solution we found; if you know of other ways to do it, let us know!
Now, take a look at ssc-tester.tcl. This program is very simple: it contains a loop that runs 16 times to create sixteen sliders, one for each of the servos that can be controlled by the servo controller. The critical command is
    scale .servo$i.scale -width 20 -length 200 -orient vertical
      -from 500 -to 5500 -command "stepTo 0 $i " -showvalue 0
This creates a slider with values from 500 to 5500, so that whenever you adjust the slider, the command
stepTo 0 slider position
will be run, with slider and position replaced by the slider number and position. This command is defined in ssctester.c by the line
  Tcl_CreateObjCommand(interp, "stepTo", &stepToProc, NULL, NULL);
The arguments are interpreted by the C function stepToProc and passed on to stepTo in ssc.c, where they are translated into commands to be sent to the serial port. When modifying the program for your own purposes, you will need to find the documentation for both commands in the Tcl/Tk language and special C functions used for interacting with Tcl. The Tcl/Tk manual will probably be your most useful reference.
New Products
ACS37200LLXTR-100B3 Current Sensor Compact Carrier -100A to +100A, 3.3V
ACS37030LMYATR-065B3 Current Sensor Large Carrier -65A to +65A, 3.3V
ACS37200LLXTR-100B5 Current Sensor Compact Carrier -100A to +100A, 5V
ACS37030LMYATR-040B3 Current Sensor Compact Carrier -40A to +40A, 3.3V
4.4:1 Metal Gearmotor 25Dx48L mm HP 24V
5V, 300mA Isolated Step-Down Voltage Regulator D24Z3F5
APM81815 Step-Down Voltage Regulator Carrier, 5.35V Out
MP6602 Stepper Motor Driver Carrier
