Controlling devices with the serial port and writing graphical interfaces
Pololu Serial 16-Servo Controller.
1. Introduction
2. Materials
3. Installing Cygwin (Windows only)
4. Writing a program in C
5. Adding a GUI with Tcl/Tk
6. Compiling and running the program
7. Conclusion
New Products
ACS71240KEXBLT-010B3 Current Sensor Carrier -10A to +10A, 3.3V
ACS72981LLRATR-100U3 Current Sensor Compact Carrier 0A to 100A, 3.3V
6V Step-Up/Step-Down Voltage Regulator S8V9F6
Motoron M2U550 Dual Serial Motor Controller (Header Pins Soldered)
12V, 2.8A Step-Down Voltage Regulator D30V30F12
75:1 Micro Metal Gearmotor HP 6V with 12 CPR Encoder, Side Connector
VL53L7CX Time-of-Flight 8×8-Zone Wide FOV Distance Sensor Carrier with Voltage Regulator, 350cm Max
12V, 2.5A Step-Up/Step-Down Voltage Regulator S13V25F12
ACS72981LLRATR-100U5 Current Sensor Compact Carrier 0A to 100A, 5V
