Support » Pololu Orangutan SVP User’s Guide »
7. AVR Pin Assignment Table Sorted by Pin
Port A Pins | Orangutan Function | Notes/Alternate Functions |
PA0 | analog input and digital I/O | ADC input channel 0 (ADC0) |
PA1 | analog input and digital I/O | ADC input channel 1 (ADC1) |
PA2 | analog input and digital I/O | ADC input channel 2 (ADC2) |
PA3 | analog input and digital I/O | ADC input channel 3 (ADC3) |
PA4 | analog input and digital I/O | ADC input channel 4 (ADC4) |
PA5 | analog input and digital I/O | ADC input channel 5 (ADC5) |
PA6 | analog input and digital I/O | ADC input channel 6 (ADC6) |
PA7 | analog input and digital I/O | ADC input channel 7 (ADC7) |
Port B Pins | Orangutan Function | Notes/Alternate Functions |
PB1 | LCD control line R/W | Divided system clock output (CLKO) Timer/Counter 1 External Counter Input (T1) |
PB2 | LCD control line E | External interrupt 2 (INT2) Analog Comparator Positive Input (AIN0) |
PB3 | digital I/O | Timer0 PWM output A (OC0A) Analog Comparator Negative Input (AIN1) |
PB4 | digital output* | Timer0 PWM output B (OC0B) SPI Slave Select Input (SS) |
PB5 | auxiliary processor control line | SPI Master Output/Slave Input (MOSI) ISP programming line |
PB6 | auxiliary processor control line | SPI Master Input/Slave Output (MISO) ISP programming line |
PB7 | auxiliary processor control line | SPI Clock (SCK) ISP programming line |
Port C Pins | Orangutan Function | Notes/Alternate Functions | PC0 | digital I/O | I2C/TWI clock line (SCL) |
PC1 | digital I/O | I2C/TWI input/output data line (SDA) |
PC2 | LCD data line DB4 | user pushbutton (pressing pulls low) |
PC3 | LCD data line DB5 | user pushbutton (pressing pulls low) |
PC4 | LCD data line DB6 | green user LED (high turns LED on) |
PC5 | LCD data line DB7 | user pushbutton (pressing pulls low) |
PC6 | M2 direction control line | |
PC7 | M1 direction control line |
Port D Pins | Orangutan Function | Notes/Alternate Functions | PD0 | digital I/O | USART0 input pin (RXD0) |
PD1 | digital I/O | red user LED (low turns LED on; connection can be cut and replaced with jumper) USART0 output pin (TXD0) |
PD2 | digital I/O | USART1 input pin (RXD1) External interrupt 0 (INT0) |
PD3 | digital I/O | USART1 output pin (TXD1) External interrupt 1 (INT1) |
PD4 | buzzer | Timer1 PWM output B (OC1B) |
PD5 | digital I/O | servo pulse output (SPWM) Timer1 PWM output A (OC1A) |
PD6 | M2 speed control line | Timer2 PWM output B (OC2B) |
PD7 | M1 speed control line | Timer2 PWM output A (OC2A) |
Misc. Pins | Orangutan Function | Notes/Alternate Functions |
AREF | ADC reference pin | |
AVCC | supply voltage for Port A and ADC | not accessible to the user |
RESET | Reset input | reset button (pressing resets MCU) |
XTAL1 | 20 MHz resonator input | not accessible to the user |
XTAL2 | 20 MHz resonator input | not accessible to the user |
*: Using PB4/SS as an input will interfere with communication to the auxiliary processor, so we recommend using it as a digital output. See Section 3.j of the Pololu USB AVR C/C++ User’s Guide for more information.
