2.a. What you will need
The Zumo Shield is designed to be mounted on a Zumo chassis kit, which is included (along with a Zumo blade) if you have a Zumo robot kit for Arduino. In addition, you will require these items to construct a working Arduino-controlled Zumo robot:
Additional required components
Please see the product description for the chassis kit for more information and recommendations about selecting these components.
Assembly tools
  • Soldering iron and solder (we recommend one with adjustable temperature control)
  • Wire cutter
  • Small Phillips screwdriver
  • 3 mm Allen wrench (hex key)
  • long-nose pliers (for bending the Zumo blade mounting tabs)
Zumo Reflectance Sensor Array
Zumo Shield for Arduino, v1.2
Zumo Robot Kit for Arduino (No Motors)
Zumo Robot for Arduino (Assembled with 75:1 HP Motors)
Zumo Shield for Arduino, v1.3
