Resources » Pololu Maestro Servo Controller User's Guide » 6. The Maestro Scripting Language »6.d. Script SpecificationsThe user scripting language available on the Mini Maestros is more powerful than that available on the Micro Maestro. The differences are summarized in the table below.
Script size: This is the number of bytes of persistent memory that can be used to store your code. A bigger script size allows you to store more servo motion frames and to write more complex programs. Stack size: This is the maximum number of values that can be on the stack at the same time. A bigger stack allows you to have more variables, do bigger computations, and worry less about whether the stack will overflow. Call stack size: This is the maximum subroutine nesting depth (the maximum number of subroutines that can be called without returning). Number of subroutines: This is the number of different subroutines you are allowed to have. The first 128 subroutines defined in your script are special: these subroutines can be started using a serial or native USB command, and each call from within your script requires only one byte of script space. The Micro Maestro only supports having up to 128 subroutines. The Mini Maestro 12, 18, and 24 support having an unlimited number of subroutines, but the subroutines defined after the first 128 can not be started from a serial or native USB command, and each call requires 3 bytes of script space. |
Wish Lists
BIG Order Form
Shopping Cart
(702) 262-6648 |
